Can't open saved rendering
I rendered my interior project using the maximum time setting. There were no issues when I rendered for around 10 minutes, but when I let it run for over 2 hours, I encountered problems with the saved file. Although I confirmed that the rendering reached 100%, the saved file has errors—it shows no image, and the file size appears as 0. This issue only started recently, as the same file with the same settings rendered without any issues two weeks ago. I’m using a high-spec computer, so I don’t think system specs are the problem. Could you please provide a solution as soon as possible? Thank you.
Did you clicked the green check mark, when rendering was done?
I always consider that behaviour as a bug. It’s so weird you have to check a box or close it for the image to be saved. The render is done, it knows the file name so why on earth wouldn’t it save the image?
Had the same issue as the TS as well and there’s no reason for KS to work that way.
